I've fixed a few bugs and rerouted some of the lines from the Ground plane to the data layer (Yes I know, bad form putting traces in the ground plane, but I just can't seem to find a route without using this plane).
I've added a Micro SD card socket as there's room for one, and hooked it up to the ESP8266, ideal for serving Webpages and images.
Ordered a new board and stencil from the Manufacturer. Let's hope everything is now correct.
