Moved from Description was in the wrong place (Doh!)
Currently tuning the Wifi Antenna. My First PCB Trace Antenna was incorrect as I mis calculated the Feed Trace Width and Antenna length. But the Ceramic antenna saved the day.
Time to search for someone with a Network Analyser or Spectrum Analyser that won't charge the Earth to use it, or find some Low Cost 2.4Ghz add on for my Oscilloscope.
