Analog Input Hack: Push Button Encoder
Hack a single MCU analog input to support push button rotary encoder.
Push button rotary encoders are popular input devices for making simple user interfaces. Using a pushbutton rotary encoder requires 3 input pins on your microcontroller: 1 for the switch and 2 for the quadrature outputs. However, in a recent application I had only 1 pin remaining on my MSP430G2553. My only choice was to leverage that pin's analog input capabilities. I first sketched out my requirements, then designed a circuit, measured the performance of my design and wrote microcontroller software to realize it.
See my project blog post https://analog10.com/posts/rotary_encoder_analog_input.html for more details.
  • 1 × Push Button Rotary Encoder
  • 1 × 3D Printed Knob The bigger the diameter the better
  • 1 × MSP430 with ADC Evaluation, Demonstration Kits, Boards and Modules / Evaluation Kits, Boards and Modules
  • 1 × 33k Resistor
  • 2 × 15k Resistor
View all 6 components
K.C. Lee wrote 06/15/2015 at 18:16 • point
From the picture, looks like you have a LCD.  What I usually do is to share the LCD data lines with buttons.  The buttons have series resistors on them so that they don't short the data lines in the output mode.  I set a busy flag in my LCD code during access, so that the timer interrupt code polling buttons would skip the scanning.
Analog Two wrote 06/15/2015 at 19:13 • point
That's a pretty good recommendation. Using that technique would also let me sense rotation while the button is pushed.
Mike Szczys wrote 06/15/2015 at 17:43 • point
I love this technique. A also never hooked up a rotary encoder to my scope and now I'm going to try with and without your circuit. Thanks for the inspiration!
Analog Two wrote 06/16/2015 at 17:18 • point
Thank you for the kind words and the HaD post.
Analog Two wrote 06/16/2015 at 18:45 • point
One thing that I should have done is determine if the encoder contacts are break before/after make.  Seems to be after based on the contact bounce levels but only a scope trace is authoritative.
Eric Hertz wrote 06/15/2015 at 17:28 • point
Clever!
AVR wrote 06/16/2015 at 04:55 • point
I thought of your hack for reading multiple buttons when I saw this funny enough lol
Eric Hertz wrote 06/16/2015 at 09:22 • point
Thanks :) I'm definitely adding this to my TODO's, or as most hackers say "to my bag of tools"
