We need a lawnmower which is can cut the higher weed also.
The conception about a 2+1 wheeled cutter.
- Vertical cutter
- 3D local positioning
- Wifi controll
- automatic recharging
from scratch ...
- Vertical cutter
- Wifi controll
The ROBOScythe almost ready for use.
The new design based on VSLOT 20x20 extruded aluminium
The drive system based on two MG996 servos and GT2 pulleys. Side effect: I created a GT2 Pulley pack on Thingiverse.
The cutting equipment based on a BLDC motor. ( +ESC )
The blade has three wings with Robotic lawnmower razors (from OBI). You can use damilhead optionally
The ROBOScythe blade has a shield. And this shield built it with two pressure sensors.
The third "gear" is a tail and stabilizes the device.
And that's all together.
Hi, my main problem - what I recognise in lawnmower concepts - the jam and the bottom mounted rotating blades can't cut the higer grass and weeds.
So, This lawnower will walk slowly and all days, and the hair-clippers format can cut the higher grasses without jam and without human help.
My hair-clippers concept imagined with horizontal vibration (not exactly than the attached image)
Do you think it might be safer to get rid of the rotating blades and instead duplicate the same concept used in electric hair clippers? http://businessfromhome.jasongregory.biz/en/video/dJU08S7Nx-E/How-stuff-works-Electric-motors-for-electric-shavers-rules-of-thermodynamics
I restarted the project and I have a new design.
