1Step 1
Source :
I followed instructions from that magazine http://boutique.ed-diamond.com/home/861-hackable-magazine-6.htm
Note that a lot of step are in common with my other #Pi MITM ..
It can be summarized as follow : -
2Step 2
Install OS :
Install last version of raspbian on your SD card
3Step 3
Configure network :
configure /etc/network/interface to use eth0 as DHCP client (which will be connected to your network), and wlan0 as fixed IP address (the tor access point) :
auto lo eth0 wlan0 iface lo inet loopback iface eth0 inet dhcp iface wlan0 inet static address 192.168.74.1 netmask 255.255.255.0 -
4Step 4
Install DHCP server :
install isc-dhcp-server
sudo apt install isc-dhcp-serverAnd update configuration in /etc/dhcp/dhcpd.conf :
ddns-update-style none; default-lease-time 600; max-lease-time 7200; authoritative; log-facility local7; subnet 192.168.74.0 netmask 255.255.255.0 { range 192.168.74.100 192.168.74.200; option broadcast-address 192.168.74.255; option routers 192.168.74.1; option domain-name "local"; option domain-name-servers 80.67.169.12, 80.67.169.40; } -
5Step 5
Install Access Point :
install hostapd.
sudo apt install hostapdIf you’re using an Edimax wifi key based on the rtl8192cu chipset, you’ll need a special hostapd build (compiled with that driver) that I found here :
- http://willhaley.com/blog/raspberry-pi-hotspot-ew7811un-rtl8188cus/ (download links seems broken)
- or http://anarsoul.blogspot.fr/2013/08/access-point-with-raspberry-pi-and.html
Then update configuration to enable a open access point by editing /etc/hostapd/hostapd.conf :
interface=wlan0 driver=rtl871xdrv ssid=torAP country_code=US hw_mode=g channel=5 macaddr_acl=0 auth_algs=3 ignore_broadcast_ssid=0Beware to change ssid and country_code according your need / region.
6Step 6
Install TOR
sudo apt install torand update configuration in /etc/tor/torrc :
Log notice file /var/log/tor/notices.log VirtualAddrNetwork 10.192.0.0/10 AutomapHostsSuffixes .onion,.exit AutomapHostsOnResolve 1 TransListenAddress 192.168.74.1 TransPort 9040 DNSListenAddress 192.168.74.1 DNSPort 53 -
7Step 7
Redirect traffic :
redirect traffic from wlan0 to port 9040 (intercept by tor) & DNS to port 53 (tor has too an option to capture DNS request) via :
sudo sysctl -w net.ipv4.ip_forward=1 sudo iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE sudo iptables -A FORWARD -i eth0 -o wlan0 -m state --state RELATED,ESTABLISHED -j ACCEPT sudo iptables -A FORWARD -i wlan0 -o eth0 -j ACCEPT sudo iptables -t nat -A PREROUTING -i wlan0 -p udp --dport 53 -j REDIRECT --to-ports 53 sudo iptables -t nat -A PREROUTING -i wlan0 -p tcp --syn -j REDIRECT --to-ports 9040 sudo sh -c “iptables-save > /etc/iptables.up.rules”You’ll need to reload iptables rules at boot by adding that line to `/etc/network/interfaces` :
up iptables-restore < /etc/iptables.up.rules -
8Step 8
Avoid wifi dongle to sleep :
If you have an Edimax wifi key based on the rtl8192cu chipset, you may, as explained on that blog, avoid it to sleep by creating /etc/modprobe.d/8192cu.conf :
sudo vi /etc/modprobe.d/8192cu.confand add :
# Disable power management options 8192cu rtw_power_mgnt=0 rtw_enusbss=0 -
9Step 9
Test your installation :
test via https://check.torproject.org/
