Hackaday.io Hackaday.io
Sign up Log in
Dream SAM2695 breakout board
MIDI synth board
julienJulien
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
7.7k views
19 comments
229 followers
  • Description
  • Details
  • Files 0
  • Components 2
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 19
View Gallery
7.7k
19
229
13
Team (1)
  • julienJulien
Join this project's team
  • Blog entry
  • OSHPark
completed project
hardware
midi MUSIC
Related lists
Projects using OSHpark boards
projects using the purple PCBs
This project was created on 06/20/2015 and last updated 11 years ago.
Description
Inspired by DreamBlaster Synth S1 and Fluxamasynth, this breakout board use the new Dream's SAM2695 MIDI chip instead of now obsolete SAM2195.
Components
  • 1 × SAM2695 Low power single chip sythesizer with effects and built-in CODEC
  • 1 × MIC5225 Power Management ICs / Linear Voltage Regulators and LDOs
Project Logs
Collapse
  • Fluxamasynth
    Julien • 02/27/2016 at 09:57 • 0 comments
    For those interseted in the Dream SAM2695 chip, Modern Device just updated their Fluxamasynth Shield with it !
View project log
Log In/Sign up to comment
Sign up with Github
OR
tedysuwarnadysoleh wrote 12/02/2021 at 01:34 • point
Dream Sam 2695 MIDI pin aout 4 pin MIDI Vin ,ground and 3,3 v conection tx ground Vin to 5v or 3,3 v
tedysuwarnadysoleh wrote 04/10/2018 at 04:18 • point
amazing good projetc ideam dream breakout just plug din midi jack so that control sound standart midi port devices
Julien wrote 07/07/2018 at 05:14 • point
http://10rem.net/blog/2012/03/31/midi-module-assembly-instructions
tedysuwarnadysoleh wrote 04/03/2018 at 02:16 • point
I have finished making pcb dream breakoutboard dream sam 2695 how to get midi port its standalone can be connected directly via midi in standard midi keyboard without any micocontroler ?
JudgeBeeb wrote 05/08/2017 at 19:27 • point
Great project. If you don't mind my asking, wWhat inductor did you use at L1 between 3V3D and 3V3A?
Julien wrote 05/08/2017 at 20:59 • point
Hi Robert, thank you ! L1 is a ferrite bead
JudgeBeeb wrote 05/08/2017 at 21:01 • point
Thanks.
Julien wrote 02/09/2017 at 15:11 • point
@tedysuwarnadysoleh
You are right, some information are missing :
- Y1 is a 12Mhz oscillator (TXC 7A-12.000MAAJ-T)
- U2 is a SOT23 LDO 3.3v voltage regulator (micrel MIC5225 or MIC5504)
- as I said any 6.3v capacitors should be OK, all 10uF are 1206 tantalum, but ceramic will works as well. I used X5R for 100nF
tedysuwarnadysoleh wrote 02/09/2017 at 05:33 • point
if I want to make a dream sam 2695 breakout any component should I buy besides ic dream sam 2605 and 5225 mic microchip especially in the picture iseperti y1, u2, C 22, C 14
Julien wrote 02/08/2017 at 16:06 • point
@tedysuwarnadysoleh
I'm not sure to understand your question, since the whole board works =< 5V, i think 6.5V capacitors would be OK ? I do not have a precise list, do not forget it's hobby works :)
tedysuwarnadysoleh wrote 02/08/2017 at 01:25 • point
when extrack and read my eagle software no details part component list volt detail
tedysuwarnadysoleh wrote 02/08/2017 at 01:24 • point
can you give me detail part list component volt detail please?
tedysuwarnadysoleh wrote 02/08/2017 at 01:23 • point
yes http://asimov.n0life.org/~julbouln/electro/dream_breakout.zip, but no detail part components list volt
Julien wrote 02/07/2017 at 18:42 • point
@oshpark Thanks :) It is so easy to do design with 0.4 QFN thanks to your PCB service !
Julien wrote 02/07/2017 at 18:38 • point
@tedysuwarnadysoleh
Thanks for your intereset ! schematics and layout are available here : http://asimov.n0life.org/~julbouln/electro/dream_breakout.zip
you can easily extract BOM with free eagle CAD software
tedysuwarnadysoleh wrote 02/08/2017 at 01:54 • point
yes layout and your schematic no detail part list component detail volt
oshpark wrote 02/07/2017 at 18:31 • point
Groovy!  Interesting project. Thanks for sharing.
tedysuwarnadysoleh wrote 02/06/2017 at 07:49 • point
can provide the name of spare parts in detail what is needed to make this dream breakout?
can provide the name of spare parts in detail or biil of material component list what is needed to make this dream breakout?
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Dream SAM2695 breakout board", please tell us the reason.
Send message
Remove Member
