The Hunt Continues
07/29/2015 at 22:53 • 0 comments7/29: I printed up a small jig to test pedal sensors. It lets me turn a magnet by hand over the sensor; this helped me pinpoint a not-bug in the position sensor coding. It turns out the AS5055A output is 0-1FFF (13 bits) over 360 degrees; the datasheet must be referring to 12 bits over 180 degrees. Anyhoo, the position sensor is tracking fine now.
7/30: The last bug has been obliterated, all scope waveforms track on all effects - time for the acid test! I hooked up a guitar to the input, and the output to the Aux In jack of a cheapo countertop stereo, and ... a split-second of sound, and <pop> no audio. Power off/on, a split -second of sound, and <pop>. WTF?
I hooked in the oscillator I was testing with, everything's back to normal; at least nothing blew. 'Sample/Hold' and 'Theremin' sound totally *awesome* as you move the magnet! Most of the rest work as expected, but Chorus seems a bit odd; then again, it could be that I'm getting cancelling effects from a single-frequency input tone.
After that, I tried the guitar again - NOW it decides to behave! Maybe I'm sitting too close to the speaker, and feedback tripped something.
All in all, it's working, just not reliably. More testing to come.
8/6: Came across a description of something called 'Track & Hold' in an essay on sample & hold circuits. It is now effect number 16 on the device. Given that the selector is a 12-position encoder, that's 1-1/3 turns of the knob to scroll through the list. I'm declaring a moratorium on new effects until I get some opinions on what to cull. My Carpal Tunnels will thank me later. Plus, as Brian mentioned in the review, I need to focus on the mechanical side of things.
8/11: My first print of a foot pedal mechanism came out with a weak layer through everything; the plastic is pale, with visible gaps between layers. Pieces fall off at the merest touch. Still, it gives me some insight into what might and might not work.
Music can change the world...
07/29/2015 at 04:35 • 0 comments7/12: Ran across a description of a Sample & Hold; 13 lines of code later, I have my 15th effect. I'll have to play with the hold time to find the best sound.
7/22: Well, after a few days tracking down a bug caused by combined misreading of the PIC datasheet AND leaving some test code un-commented-out, I finally saw my waveforms change smoothly in response to the pedal magnet. YES!
Tonight I'm off to the local makerspace (Sask TechWorks) to see about printing a case and components.
7/28: after various fits and starts, I got a 'learning prototype' printed - as in '"now i get to see how bad my Sketchup skills are". :)
Being that it was a flat box, the corners pulled up - oops, lesson learned. And I STILL can't figure out how the Makerbot printed several centimeters of (millimeter-sized) horizontal beams WITH NO SUPPORT STRUCTURE! How'dtheydothat?
Anyhow, in spite of the pulling, the important areas printed fine, and showed me some changes that need to bemade for ergonomics. All in all, for a first pass, I'm satisfied.
Tonight it's back to the 'space for more...
