Docta Vox - Voice controlled outlets
Voice control of power outlets
"Lamp on." *click* "Lamp has been turned on." *commence feeling powerful*
The project interfaces with Google TTS and STT functionality to communicate. It also sports an iOS interface. The outlets cost about $6 each and are wireless. The entire project will cost less than $50 with shipping. Plan about a weekend to complete! All the software is open-source (it is posted below!) and is based around open-hardware: the Arduino!
From the Latin, "Docta Vox" meaning "learned voice" or something like that according to Google Translate. It sounded cool and I'm bad at naming things anyway. So there you have it.
This project uses Processing with STT (speech to text) and TTS (text to speech) to allow verbal communication with the program. The program communicates with an Arduino with RF transmitter via serial. A simple demonstration of the project in action is found here.
I started this project a couple of months ago with the simple hopes of controlling an outlet. Flashing an LED is great, but when you need to make something more substantial happen, this is the thing to do. I was almost tempted to get relays like this one. I decided against that because of this excellent tutorial called "Arduino Controlled Relay Box."
After I priced it all out at Lowe's and Sparkfun, I found that each box would cost around $30. These boxes are large, don't forget, and require a wired connection to the Arduino. To control five outlets would cost $150 in components plus low-voltage wire to run around the house to each outlet. I'm not sure my family is going to be ok with bundles of wires running down the hall.
Time for a better solution. I scrounged around the vast caverns of Amazon to find what I thought would be the best fit for my plans. Etekcity 5LX remote outlets are just the ticket. They cost a whopping $35 and offer control of 5 outlets and negate the need to run wires. Not bad.
I bought the set of 5 outlets and two remotes, but you can also order almost any combination by viewing the related products on the page.
My first plan was to hack the remote apart and add transistors to the buttons. This began one of the larges failures in my hacking career: I fried both remotes! Ah! I wound up ordering a new remote and trying a much safer method. This new method was to sniff the RF codes of the remote and retransmit them using the Arduino. Of course, this meant another stop at Sparkfun for their beautifully simple RF products: RF Receiver, RF Transmitter. Both of these <$5 components proved to be quite valuable.
Once again digging up some help online, I came across the an exquisite library made for just such a thing as what I was doing. It's called the RCSwitch Arduino library.
After downloading and installing the library, open up the advanced receive sketch and follow the link in the commenting to see the tutorial. Really, you can operate it without much guidance. The code is simple, and it literally spits out codes on screen as you press buttons on the remote. I found that on my remote the decimal value was the easiest to work with. It will spit out a code that looks something like this:
Decimal: 5592371 (24Bit) Binary: 010101010101010100110011 Tri-State: FFFFFFFF0101 PulseLength: 185 microseconds Protocol: 1
Raw data: 5816,220,544,592,152,224,536,596,156,220,540,588,160,220,540,592,172,204,540,596,160,212,544,592,164,208,544,592,
164,212,548,588,164,208,544,216,544,588,168,208,548,208,544,208,544,208,548,208,548,
For the practical purposes of this project, you only care about the part that says, "Decimal: 5592371" You should press each button on the remote in an order that you will remember and then copy all the data from the serial monitor into something else (Notepad, or Notepad ++ would be great). Save it.
Next, open the transmit sketch and begin testing. I decided to make the repeat value 9 (I discovered that is what the remote itself sends) and I changed the decimal code to the one for "ON" on my first outlet. I uploaded the sketch and watched it work! Success is great! I then modified the code to do all 10 buttons on my remote. I added the switch/case statement to shorten it a bit. If you are wondering why I went with a serial interface, it is so that I can more easily interact with Processing in the next section of this tutorial....
  • 1 × Etekcity 5Pk. Remote Outlets About $35 on Amazon.com
  • 1 × RF Receiver (434MHz) From Sparkfun. About $4
  • 1 × RF Transmitter (434MHz) From Sparkfun. About $4
  • 1 × Arduino! Of course!
  • Hello? Hello!?!?
    trademark • 05/12/2014 at 00:43 • 0 comments
    Plugged the thing back in today and everything works fine except voice recognition! Google must have changed something up a bit. I'll need to do some investigating :|
  • April Fools Day
    trademark • 04/02/2014 at 02:43 • 1 comment
    I used the system on a teacher.  I controlled his desk lamp by sneaking one of the remote outlets when he left the room.  Instead of using the voice control, I just used the up and down arrows on my laptop.  The result was excellent, and the Arduino fit nicely inside my backpack.  New best prank!
View all 2 project logs
  • 1
    Step 1
    I wrote full documentation on the site http://www.processingandarduino.weebly.com  and also in the description of this project (same as dedicated site:  copy/paste)
View all instructions
