Off-topic: Shameless self promotion
03/26/2017 at 00:52 • 0 commentsI've entered 2 mini projects for the 2017 Hackaday prize, I would really appreciate it if any of you out there would like the below projects as I get $1 for every like.
Thanks for all that are following the project
12/23/2015 at 17:53 • 0 commentsI do plan to eventually do a PCB for it. Up until now I've soley used OSH Park for my PCB needs. Their PCB's are of excellent quality, but at $5 USD per a square inch it would get a bit expensive to use them for this project as some of the sketches that I've done on Kicad consume a few square inches of board space. The Chinese PCB fabs are looking like a less expensive option although their quality is not quite as high as OSH Park's offerings.
Anyways, Merry Christmas!
1st revision of Schematic and more!
07/27/2015 at 20:53 • 0 commentsI finally did the schematic today. I also created a GitHub page for the entire project which contains the project code, the KiCad files and a pdf version of the schematic if you don't have KiCad installed. You can find it here.
Yes, yes I know
07/27/2015 at 00:56 • 0 commentsI've been neglecting to provide additional documentaion. I plan to do a schematic in KiCad soon.
