To tidy up a little bit my projects I will push the µ7-project into a log of tiny7 The following text is mostly just a copy from the old µ7 project page:
This is just an idea how to make #tiny7 smaller. Smaller IC package (QFN) and samller parts are used. The dispaly is 0,36'' 7 segment display.
It should be 100% compatibel with #tiny7 . The same library should be used. But µ7 is not chainable (yet?).Components
- 1 × HC595 shift register DHVQFN16 package
- 2 × 4x1k resisitor array
- 1 × 10k resisitor 0402
- 1 × 100nF capacitor 0402
- 1 × 0,36'' seven segment display
- 1 × pinheader
- 1 × PCB Electronic Components / Misc. Electronic Components
