Putting it together
07/01/2015 at 19:57 • 0 commentsFirst the frame, 20x80 + 20x40 + crossbards and all the bits to hold it together.
3d printed a part to help hold the tap, got it from Dave's Stuff who did a much more indepth photo build than i am so far.
http://blog.davehylands.com/2015/03/ox-cnc-router-unboxing.html
Put together the end supports for the outer frame, taped the two holes and added them in
I found it easiest to build the outer frame, square it, then slide the cross bars in at the edges with the triangle clips and slide them in from both sides to here, then tighten.
Finding all the parts from around the garage.
added the wheels
motor is a pain to mount i just used an open spanner to hold it as best i could
The front of the motor mount doesn't fit the hole..... so i'll have to cut out some more of the oval...
Comparison of CNC'd parts
07/01/2015 at 19:46 • 0 commentsThe sandblasted parts came from the SW3D kit, and the smoother ones came from ebay.
charliex
