1Clone github repository
2Adapt configuration
Adapt the cloned mos.yml and insert the following information according to your wishs
- WIFI SSID and password
- MQTT broker address
- MQTT topic the data should be sent to
- Time for deep sleep
3Run mos build
Run the mongooseOS build script. For this change to the folder where the cloned files can be found.
Run in terminal
mos build -
4Flash compiled script
Run in terminal
mos flashIf the tool doesn't auto detect the port the D1 mini is connected to you have to add --port after flash.
difitux
