The Android app allows for remote monitoring without having to be tied to your workbench. The app works Bluetooth 4.0 or direct via USB OTG. Of course the latter you would still be tethered, but not if you have a Pebble smartwatch! It will pipe the data to your watch if you enable the option.
One thing to note is I need to work on negative values. There seems to be an issue with the min value as it is always 0mA.
