The 3D printed case is almost complete. I made some adjustments to the nubs inside to keep the backpack snug when you push the button. Before it was causing the case to come off.
The same for the bottom portion of the case. Now when you pull it apart the case stays attached. There is very little play in the case.
Here are some of the updated pictures of the case printed with an Micro3D.
