The socket for ESP8266 is connected to the FPGA only, so we need to connect the ESP to UART for testing first.
This is just a "wiring" code for FPGA, creates wires from ESP to UART pin of FT2232H.
// ICEd UART to ESP8266
// What it does: connects FTDI channel B pins to ESP8266 UART
module top(
// RGB LED
output LED_R,
output LED_G,
output LED_B,
// Small SMD LED (green)
output LED_small,
output ESP_TXD,
input ESP_RXD,
output ESP_RESET,
input ESP_GPIO0,
output ESP_GPIO2,
// FTDI FT2232H Channel B
input BDBUS0,
output BDBUS1
assign LED_R = BDBUS0;
assign LED_G = ESP_RXD;
assign LED_B = 1'b1;
assign ESP_GPIO2 = 1'b1;
assign LED_small = ESP_GPIO0;
assign ESP_TXD = BDBUS0;
assign BDBUS1 = ESP_RXD;
endmodule // top
Sure pin constraints too, then load the FPGA, and ready to test.First test worked - the only issue was wrong baudrate setting!
