Version 3
07/08/2015 at 08:05 • 0 commentsAfter much testing it turns out that long arms and 9" props in a Y4 configuration has almost no yaw authority at all!!
It made the copter practically useless for AP as you couldn't keep it straight let alone pan a shot.
So I decided to go with a standard tricopter and got myself one of these:
It's a ToughTilt mechanism from flitetest.com and it's rock solid. It has an almost hydraulic feel to the movement.
After a test with the 9" props it was obvious I needed something bigger.
So I went with 850kv motors and 11x5" props. This gives me a nice 50% hover:
Cut, Paint, Repeat
07/05/2015 at 20:25 • 0 commentsThe basic method I used was to cut the parts on my Shapoko CNC mill, although a steady hand and a jigsaw/drill can yield that same results, the sand them down to clean up the edges and ensure the holes were all clear.
Next I needed to paint them. The reason for this is a little know secret... once you spray paint any material black, it magically takes on all the properties of Carbon Fibre!! thats science kid!! :)
I use simple spraypaint and clear laquer, about 2 coats of each.
The rest is history but here are some build pics:
And Version 2:
