Photo build log
10/27/2015 at 22:21 • 0 commentsFinally, i've managed to create photo build log (imgur.com). Now to the EAGLE files. I have to clean them up a bit and enter values of all passive components on the schematics. Stay tuned!
IRIS firmware/sdcard images repository, build log, PCB's
10/06/2015 at 10:29 • 0 commentsSdcard and firmware images are here (github.com). Minimum reasonable setup required to run this firmware is Raspberry Pi, NVRAM+RTC module, wifi stick, and some sound source - headphones, speaker or bluetooth speaker (BT stick required). In the next few days i'll try to create a photo build log, and separate github repository with EAGLE PCB files for the entire project.
Core application sources are on github now
08/16/2015 at 18:58 • 0 commentsIRIS core application sources are here (github.com).
