Anyone is welcome to contribute to this project however all designs should be done in a way as to ensure they are compatible across documents. This means paying particular attention to net names, port naming, etc. (all of the stuff that makes design tools finicky to work with, if you don't think about it in advance).
All of these resources are somewhat "random" in that there is no order to how I have added them nor any order to how I will add more. There is order however to how the design elements are categorized and the basic categories include:
- Power
- Data Conversion
- MCU
- Wireless
- Wired
- Sensors
- Actuators
- Interface
- Control
The underlying goal of this project is to create a pool of standard resources anyone can pluck from and simply put together Hardware without concern for too much in the way of low-level detail. That said, as the project progresses I will be adding Vin and Power req's, as well as a BOM for each document. At some stage I will also introduce signal mapping sheets that account for the variety of ways signals might be oriented and mapped sheet to sheet, pin to pin. A ton of thought has gone in to how to make this work and it's down to implementation. I'll also try and document the structure of sheets req'd to make this work, so if you have content to share, you'll know how to conform it to a standard that works for everyone.
If you want to contribute, please let me know and I'll be happy to add you! If you want to use any of the stuff, take it. It's free and open and available for sharing. Great if you can use it! Better if you can give back!
technolomaniac
AdityaPrakash23
Lorin Briand
Kaspar Emanuel
do you have a link to the project with the stuff your publishing?
regards in advanced.
