Today I designsparked :)
At the top is the same interface as the camera Module.
Below in the "Big Cage" on top there is the place for a LiPo Battery, it should be secured in Place by the Noses.
At the Bottom there is some kind of Spring mechanism to snap in the PCB.
The Size is about 50,5 x 35,99 x 23,5 mm.
I'm curious.. is it possible to calculate the probable weight or Volume of the Model?
I'm trying to get the Model Laser Sintered :-)
If you can export it to an stl, just upload it to shapeways, there you'll see the volume and also get a price rating!
Thank you! It's Material Volume 1.9652 cm3 so its only about 2g? and 6€
Best Regards / Gruß Stefan
