After seeing another NFC ring project on here, I decided I wanted one too.
I used the same basic idea, only with stuff I already had lying around.
It doesn't look quite as nice as Joes, but seems to work just as well.
I tore the NFC guts out of a cheap key chain tag from eBay.
The ring form was made out of duct tape around a sharpie.
This was made the correct size by testing with another ring I had that fit.
A layer of electrical tape, sticky side out went around that.
Then the coil was wrapped around that, and re-soldered after I broke the wire off the chip.
Once It was tested and verified functional, it was potted in hot glue.
While still hot, it was turned in a lathe, and smoothed out by hand.
Once it cooled, the edges were trimmed with a side cutter.
Overall it took about 45 minutes and a $2 nfc tag.
The software I used to unlock my phone is NFC LockScreenOff Enabler.
