A bottle cap with a propeller that uses a pressurized soda bottle to drive a tip jet propeller
I've added a new picture with a more complete assembly, this should clear things up a bit more.
The air valve is located in the bend bit that's on the red bottle cap. It wasn't visible in the previous subassy.
It not intended for flight only, but it should non the less. We will include a "straw" to the bottom of the bottle so the bottle hangs from the prop. Or you can use a bent straw and lay it flat. ty-rap it to a roller skate for a car, or 2 additional bottles (which can be charged as well) and get a boat.
As for control, we don't have any:) open the throttle and see what happens.
I get the construction/assembly from your description and seems like a pretty solid idea. I like how simple it is - Except for the props.
What I do not understand is the location of the Bike/Air valve. its not in the same axis as the M8 bolt right? I'm guessing its off center, not visible in the 3D drawing.
Also, do you intend for this to fly? cause controlling a water bottle over a single prop is going to be fun - Inverted pendulum out of hell. Thats something id like to watch!
Cool project.
... did this fly?
