Hello HAD, soft-propeller...
A project log for Soft Propeller
DIPFORTy1 "Soft-Propeller" Zynq-7, Dual CortexA9+ FPGA DIP40 Parallax Propeller I compatibles footprint
antti-lukatsAntti Lukats • 07/17/2015 at 20:46•1 Comment
Hello world is usually simple. But it not always works the first time, so it always a good feeling seeing some thing to greet you.
Here it goes :)
The counter that was clocked from FPGA internal free running oscillator is no clocked from PLL in the PS subsystem, PS UART1 is routed via FPGA fabric to some pins, well in this case to the pins in the JTAG-UART combined debug header-connector.
Maybe the hello could have worked first try also, but I had another Zynq PCB from our oven a few hours earlier today what I had to test (succesfully). Maybe there was no more juice at 2200 hours.
But important is that the DIP40 Zynq mod is alive, loads FPGA and says hello :)
Abraham wrote 07/20/2020 at 20:13 • point
Hi, for this particular test, how do you enable that free running oscillator within the zynq processing system block?
And for the propeller code, did you perform the translation from Altera to Xilinx or use some of the Xilinx ports published on the Parallax forum?
