Here's a short demo video of SmartEE in action.
Here the plug is connected to standard incandescent lightbulbs on a dimmer. The software interface is [wattsworth] (a larger power monitoring project that should be released later this year). Using the python libraries with SmartEE makes it easy to add smart plugs to any project.
The github repository has 3 folders- covering each section of the project
- Hardware: Schematics, PCB layout, gerbers, and BOM
- Firmware: Code for the SAM4S. Check out the compilation instructions in the project log.
- Software: Python modules for incorporating SmartEE plugs into your own projects.
As always, please let me know if you have any questions!
