Rewrote the signing library
07/06/2017 at 12:00 • 0 commentsWoop!
The signing library is now a lot more useful, making it possible to use any payload you wish however you wish. More testing is needed but it looks promising. -
Signing
01/24/2017 at 20:10 • 0 commentsSigning library has been turned more universal, but because of that I also broke it, needs more work but it's looking okay. github.com/Avamander/RF24Signing
Small status update
11/13/2016 at 19:21 • 0 commentsTo whoever stumbles upon this:
I have temporarily suspended the development of my home automation system. Will return to this if I find time to spare. One day...
Fun stuff
05/26/2016 at 18:54 • 0 commentsWell, I have to now manually manage AVR's memory to properly buffer payloads that are almost going to be sent. It is taking a lot more effort finalizing the library than anticipated.
Signing the messages
02/28/2016 at 15:27 • 0 commentsThe signing library I have written in the past few days has finally started functioning in only a little below optimal parameters. But it'll take quite a bit to refactor it.
Busy times
02/24/2016 at 19:56 • 0 comments- Writing basic signing library (software based at the moment) I want the base to work properly.
- Got proper nRF24L01+ modules. Seriously f*** the clones
Christmas
12/26/2015 at 15:36 • 0 commentsThings in progress:
- I am currently exploring signing RF24Mesh messages with ATSHA204A
- Long term testing the library if any issues arise
- PIR sensors (those 0.99£ ones) are somewhat tolerable quality, in many cases it does not detect quick enough.
- Rewriting control utility in Python
- Learning Java for Android app (Material design is awesome)
Took some photos too, will see if I will be able to upload some.
Rewriting
11/07/2015 at 23:09 • 0 commentsWeekend begun, spent a day fixin' stuff
- Doing a GUI for the project in Python is times more complicated than in Processing, but it's going to be worth it
- The cheap PIR modules you get from eBay are funky, they seem to calibrate themselves to a certain environment or light setting and then they give false readings, I need to find something that auto-recalibrates.
- My common code library is awful, it desperately needs rewriting. I would just love to nuke the library I wrote but I need it :(
Hopefully I'll start making more progress now that Arduino IDE actually works properly. (If one excludes my poor Python GUI writing that delays things)
Busy times
10/13/2015 at 16:51 • 0 commentsDid quite a bit:
- Found an old vintage phone (huge one) from the attic, stripped empty inside before I got it.
- Soldered together a few more nodes, last one looks really neat.
- My overlay chip does not want any changes to it's EEPROM for some reason, will delay using it :/
- My ethernet module came in the mail, quite neat, but I have no idea if I'll use it in my home automation. Maybe as a backup master node if one goes down? I'll see if the library supports it.
- Writing an Android app is a PITA on an old computer.
So many things to try out and so small amount of free time.
More fancy hardware
08/10/2015 at 11:35 • 0 comments- Just received my MAX7456 overlay board altho programming it was a pain.That means my TV got smarter. When the system is done, I'll upload 1.5.6 Arduino IDE compactible libraries.
- Moved few more nodes to prototype plates instead of breadboards they were on.
