This is a just-for-fun-project. I wanted to make a small circuit which uses only a few discrete components to make a chasing light like effect.
The PCB is a circle with a radius of 13.5mm. The circuit consists of 7 inverter stages which are connected in a circle. Hence the name "Ring Oscillator".
Each invertar consists of a N-Channel MOSFET, two resistors, one LED and one capacitor.
marble
ElectronicABC
Brian Lough
DIY GUY Chris
Dillon Nichols
I made something similar. I am using a BC847 and a slightly modified circuit. You can look at the image and a video here https://www.instagram.com/p/Bzr0lXBn9m9/
