Amazon Echo Voice Command Automation
Back to overview
Yes! You can now have "Alexa" do what you want, when you want, by using a Raspberry Pi.
krschacht wrote 12/16/2015 at 06:03 • point
I'm getting ready to do this hack. Couple quick Q:
1) You mentioned you're using e-speak and bixycron (sp?). I got e-speak, but what's bixycron? I think I must have misheard you in your video.
2) This 3v3 will work, right? http://www.hobbyengineering.com/H5492.html I just want to make sure there is nothing special I need for the Echo remote.
Robert Hillman wrote 10/15/2015 at 23:19 • point
How was the audio connection made? Looks like you used a headset plugged into the auto jack of the PI and placed the ear piece over the remote mic?
gamaral wrote 10/18/2015 at 08:25 • point
Yeah, simple earbud over the mic input. If you want to go hard-core, you could remove them mic IC and bitbang away.  :)
jjlink wrote 08/22/2015 at 17:48 • point
I have the "Slice of Raspberry Pi" up and running. I login as root. But all I get is this:
-sh: alexa: not found
So what am I missing?
Thanks
