Hackaday.io Hackaday.io
Sign up Log in
DIY JTAG progammer for CPLD board
Companion project to my DIY CPLD board project here
hackhead79hackhead79
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.1k views
1 comments
3 followers
  • Description
  • Details
  • Files 0
  • Components 3
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 1
1.1k
1
3
2
Team (1)
  • hackhead79hackhead79
Join this project's team
ongoing project
This project was created on 04/02/2014 and last updated 12 years ago.
Description
This is a prerequisite project to my DIY CPLD project here on hackaday.io.
The CPLD board needs a means of being programmed: hence this project to build the matching programmer for the board.
For this I'll follow the tutorial on startingelectronics.com (http://startingelectronics.com/projects/xilinx-parallel-programmer/ ).
Components
  • 2 × 74LVX 125 D Quad 3-state buffer as a replacement to the 74HC125N needed for the tutorial
  • 1 × set for 14-pin ribbon cable including plugs
  • 1 × a few other components - see tutorial
Project Logs
Collapse
  • Only a few updates here
    hackhead79 • 04/02/2014 at 20:50 • 0 comments
    Most of the updates will be found at my other project (DIY CPLD board). I'll post a few updates of the PCB making process here though.
View project log
Log In/Sign up to comment
Sign up with Github
OR
Peter Burkimsher wrote 06/30/2014 at 19:35 • point
The parallel programmer is great for desktops, but I have a laptop without a parallel port.
I'm using the gz_load program from the GuzuntyPi project on my Raspberry Pi, which works to program 3.3V JTAG.
https://github.com/Guzunty/Pi/wiki
I also have an FPGA, but that uses 2.5V JTAG. Building a voltage level converter for that is an ongoing project for me!
This is a very advantageous yet easy to make project. We call it " Smart Electric Board".
Project Owner Contributor
ashumhrprojectsASHUMHRPROJECTS
Three RP2040 evaluation boards
Trinity Project
mirkoMirko
My Digital Electronics class is building a programmable board with various sensors to experiment on.
Patriots Companion
xaiXai
A project in waiting...
STEbus Z280 board
keithKeith
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "DIY JTAG progammer for CPLD board", please tell us the reason.
Send message
Remove Member
