CNC_jogger.ino
Arduino-based software for manually controlling my CNC machine. Niew, slightly improved version (December 2016)
x-arduino -
25.80 kB -
01/07/2017 at 12:08
Download
analogKeypad.h
The header of the analog-keypad library used for my machine
x-chdr -
956.00 bytes -
07/24/2016 at 15:37
Download
analogKeypad.cpp
The .cpp of the analog-keypad library used for my machine
x-c++src -
3.00 kB -
07/24/2016 at 15:36
Download
numericDisplay.h
The header of the arduino-library for showing my position numbers
x-chdr -
569.00 bytes -
07/24/2016 at 15:36
Download
numericDisplay.cpp
The .cpp of the arduino-library for showing my position numbers
x-c++src -
3.74 kB -
07/24/2016 at 15:35
Download
CNC-mill_freecad.fcstd
The mill as freeCAD design.
x-extension-fcstd -
168.01 kB -
07/24/2016 at 15:33
Download
PCB_milling_precision_test.svg
The .svg file of the test-pattern. You can use the plugin "gcodetools" to create g-code from that pattern. Note that the milling-speed for the speed-test was changed with a text-editor afterwards.
svg+xml -
29.37 kB -
03/02/2016 at 08:18
Preview
PCB_milling_precision_test.ngc
This is the G-code for the test-pattern shown in my second Follow-up video.
ngc -
11.29 kB -
03/02/2016 at 08:12
Download
