I'm use the ADV7611 to get HDMI work. The problem is that you can't buy a chip with HDCP keys, in case you haven't bought HDCP-license. You only can buy the "professional" version of the processor - with has no-HDCP support. The name of the part show up if it's a "professional" (or industrial/automotive version). The full name of my chip is "ADV7611BSWZ-P". The "P" at the end means for professional (as I know)...
klaute
