The Melnor Digital Water Timer can be found here: LINK
Recording my attempt to hack a 4 valve Melnor Digital Water Timer and add IOT functionality to control it remotely
Ok this project isn't updated anymore and since I made some progress I created a new project here https://hackaday.io/project/159915-hacking-the-melnor-53280-enhanced-watering-timer
The valve assembly is controlled by a wire that has 7 pins. Initial attempt at measuring activity with a voltmeter resulted in frying the control unit, I must have shorted two pins. So I will have the control unit replaced and next will use the logic analyzer instead of "running" a voltmeter probe across the pins.
I have had the same idea, just haven't been willing to risk breaking my only valve controller while I am still using it. Have you made any progress?
https://hackaday.io/project/171942-two-zone-wifi-water-timer
