Adding Sensors to an Arduino Data Logger
12/18/2017 at 04:30 • 0 commentsI finally put together the prequel – months after the I2C registers tutorial was released... but hey if Hollywood can do it....
This adds to the set for beginners that I’ve been working on for my teacher friends. There are so many different kinds of sensors, that there is necessarily a lot missing from that post (like async serial..). So Adding Sensors (part 2) will follow in the new year when I can grab the time.
Configuring I2C Sensors with Arduino
11/04/2017 at 17:55 • 0 commentsI know it's been ages since I posted, but I've been working on a complete overhaul of the code-base for our data loggers. In the process of untangling all that spagetti, I standardized the I2C sensor functions and posted a little tutorial about it on the project blog:
https://edwardmallon.wordpress.com/2017/11/03/configuring-i2c-sensors-with-arduino/
Even when I grab an off-the-shelf library for something, there are usually a few registers that I have to set before a sensor runs in a mode appropriate for environmental monitoring.
Screw Terminal Promini Logger
06/22/2017 at 00:54 • 0 commentsWhile breadboard loggers are quick, the connections tend to be a bit too fragile for serious testing. So I've come up with a configuration based on a screw-terminal expansion board that breaks out all the pins nicely:
Arduino Data Logger: 2017 Build Update
As a bonus, I've also described modifications that bring this 4-part logger below 0.02 mA sleep current. Current assembly time for the basic unit is under one hour.
Switching off SD cards for Low Power Data Logging
05/22/2017 at 16:12 • 0 commentsI saved SD power control to the end of my quest for low power logging, because I was worried about the potential weirdness that could arise with the Arduino libraries. But after a reasonably thorough round of tests it does seem to be working OK with a BJT switching the ground line.
This brings these penny-part loggers into multi year territory on 3xAAs.
Miscalibrating Thermistors with a 3.3v Arduino
04/27/2017 at 18:27 • 0 commentsI'm slowly learning my way through the lmitations of the Arduino platform, and I recently stumbled into the issues with cheap regulators & bandgap references
Calibrating Oversampled Thermistors
I'm sure I will be kicking the "resolution vs accuracy" can around the block a few more time before this project is done.
Enhancing Arduino ADC resolution with Dithering & Oversampling
02/27/2017 at 19:34 • 0 commentsI could never find many decent explanations of how to do oversampling with an Arduino, and it has been bugging me for a while as the technique seemed like such a good idea.
So I decided to do something about it:
Now before the old hands pat me on the head, saying "That's nice dear..." I just want to mention that it took more test runs than I even want to think about to get this stuff sorted out. So if that information was all lying around somewhere the whole time, and I just missed it... don't tell me about it... I don't think I could handle the news :-)
Cave Pearl Project 'Year in Review'
02/04/2017 at 19:38 • 0 commentsWe just fired up a new collaborative project, and some of the academics from the other university suggested that the blog was something of a spaghetti monster, and that they had a hard time navigating through it all.
So I whipped up a short summary page which brings together all the latest version info:
☀ How to Build an Arduino Data Logger ☀
There's probably nothing new there for this crowd, but it's worth noting that since the beginning of the project, we've accumulated more than 700 months of operational time with these little guys, and about half of that is in underwater. We have only had one housing failure, and that was from using bad epoxy.
I've also posted a short video clip from one of our recent deployments on the Year in review post which might be of interest to others here doing underwater projects.
Cheers!
2016 Cave Pearl Project ‘Year in Review’
01/13/2017 at 19:36 • 0 commentsI haven't had a whole lot of spare time for updates lately, but I did manage a short year in review post over the holidays:
I generally avoid waxing philosophical on the project blog, but once in a while it kinda just leaks out...
2016 ProMini Build Update
10/27/2016 at 17:15 • 0 commentsAfter watching people build loggers based on the plans I released last year, I realized that simply learning to solder was the biggest challenge they faced. So I reconfigured the basic logger design to use crimped jumpers: 2016 ProMini Build Update
The changes bring the platform in under $10, and reduce the assembly time below 2 hours (for me). The students still need about 6 hours to assemble a platform from scratch, but I figure that is pretty good for folks with no experience.
I2C pressure sensors work on >20m cables!
09/22/2016 at 04:04 • 0 commentsSo it turns out that you can put I2C sensors on the end of some very long cables:
This opens up some interesting environmental monitoring possibilities. Much as I love the long runs I get with DS18B's, there aren't many other sensors in the one-wire world. But if I eventually get I2C out to 50m, then my problems would be solved...
