Digipot Application
08/17/2015 at 16:51 • 0 commentsThe main reason we started working with it was to automate test jigs for our other Flex Modules. Hopefully there is general interest in the technology, but in general it is useful for calibration and analog automation.
Testing soon
08/17/2015 at 16:48 • 0 commentsWe have the digipots, but not the power supply components. We will have them in stock soon though to test.
Wiperlock
08/17/2015 at 16:46 • 0 commentsThe power supply for the wiper lock should be efficient, but is meant to only be enabled in special use cases. We may make it an optional set of components.
Almost 2 layer
08/05/2015 at 06:07 • 0 commentsThis design was almost 2 layers. There were about 5 traces I could not route and so I converted to a standard 4 layer stack up. I might revisit this issue after confirming the circuit function.
