White light source
02/13/2017 at 06:44 • 0 commentsI am curious if I can add a white light source with variable temperature. I expect it to be a RGB LED tuned to approximations of the K requested. I have found an algorithm at http://www.tannerhelland.com/4435/convert-temperature-rgb-algorithm-code/
Additional source lighting?
08/17/2015 at 20:45 • 0 commentsThe reference design does not show it, but earlier sensor designs seem to perform best with the addition of a white LED source. We may have to add one to this Flex Module.
1v8 vs 3.3v
08/17/2015 at 20:43 • 0 commentsThe model we are using is 3.3V. The later model is 1.8V, but as far as the datasheet shows, they have basically the same features.
LED isolation
08/17/2015 at 20:42 • 0 commentsThis is a single module, so hopefully it is pretty easy to implement. Many other light sensors need to have a source light that is protected from the receiver.
Samples?
08/17/2015 at 17:45 • 0 commentsWe are waiting on some samples from AMS, but nothing yet.
Chris Hamilton
