BLE uploading
08/17/2015 at 17:14 • 0 commentsThis design is pretty easy to design. We are using the Seggar J-link, but still having problems including the BLE stack. I'll be working on this soon.
Glue haptics
08/17/2015 at 17:12 • 0 commentsIn our initial layout, we chose to hot glue the motor on to the board. I do not believe it will be durable, but we will experiment with epoxies later.
08/16/2015 at 10:00 • 0 commentsThe circuit board may be glued or sewn to fabric. We recommend gluing at this point so that the board is on a more comfortable cloth around the skin. So any strap with velcro should work out.
Current Design
08/16/2015 at 09:58 • 0 commentsWhile we are waiting on the charger flex module, we made a design using a simple watch battery. It is not perfect, but it is simple enough. Instead of the Qi/USB Charger Flex Module and a curved Li Poly, we used a CR2450 battery holder.
