New video posted
09/08/2015 at 05:19 • 0 commentsFinally got video of the updated Sideway:
Playing with controls
08/21/2015 at 07:52 • 0 commentsSince I have a Nunchuk controller, and it has an accelerometer in it, I thought it'd be interesting to add a mode to the controls that uses the accelerometer angle to steer. I patched it into the code tonight in a couple of minutes, and it feels surprisingly intuitive already. I'll give it a couple days to get used to it and try to get a new video up
Sideway gets a facelift
08/13/2015 at 22:04 • 0 commentsSideway got it's first facelift! I changed the physical build significantly, but the electronics are identical.
V2 puts the wheels farther apart to improve the stability of the platform. I made the deck out of simple plywood for the moment, though I plan on actually creating a custom one using a combination of hardwood and fiberglass to improve the strength.
The gear ratio is a little lower than before, so it's faster, and it's using belt drive instead of chains, which makes it almost silent compared to what it was.
The overall construction is MUCH lighter. Using belts instead of chains and a wooden deck instead of steel frame dropped a good amount of weight, so it's more agile, and it's easier to carry. I haven't measured the difference, but it's very apparent in how it handles.
I'll probably make the next deck a little bit wider, and a little longer, but overall I'm very happy with this revision.
Jason Dorie
