Ever had to design a project with limited space, only to find that you were running out of room for that bulky 6 pin connector?
Well this little device allows you to use the uSD card reader as the Arduino ISP connector by breaking out the 6 pin header to contacts on the PCB which mimic a uSD card. Once the target device is bootloaded, you can remove this adapter and you are left with a functioning uSD port. The Arduino Reset signal is carried by pin 8 of the uSD card connector, making use of a N/C terminal disregarded by the uSD card itself.
The device also contains circuitry to power the target device, allowing ease of use when programming multiple target devices.
hey, could you upload the files here or on github maybe? Or are you selling the boards by any chance?
