Wait long Time for the new PCB, Error from me and OSHPark, OSHPark forgets the VIAs and I order in the wrong thickness, i Order new and wait for the New One.
Lock very nice its better as the First Version and not usable.
Can you see whats is not ok ?
Could let me know the right thickness on OSH Park?
@Knudt sorry to see this happened. please email support@oshpark.com and we'll see what we can do.
thanks,
drew fustini
<drew@oshpark.com>
@oshpark
Is already okay, I've already opened a ticket for notice, and a new printed circuit board ordered.
Even if your mistake would not have been inside, I have also made a mistake and thus made the board unusable anyway.
I guess you're talking about the edge connectors, can't you sand them down? @oshpark - is there a way to prevent something like that?
No i have Edit the Text the Fail is the VIAs and my Fail the wrong thickness, Double error ;(
The corners connectors are outside the specifications given by OSH Park, which is problematic with such circuit boards, but is not the problem there is enough sanding.
ah okay. sry, was wild guessing :)
