Hackaday.io Hackaday.io
Sign up Log in
Guitar Amp Refurbish
Cleaning up a practice amp found in the back of an antique store
nathaniel-graffNathaniel Graff
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 5
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
315
0
1
2
Team (1)
  • nathaniel-graffNathaniel Graff
Join this project's team
hardware
ongoing project
amplifier REFURBISH
Related lists
Guitar Projects
Guitars and Guitar Accessories
This project was created on 07/29/2015 and last updated 11 years ago.
Description
I found this amp in the back of antique store sitting on a dusty window sill. It seemed mostly intact, if a bit worse for wear and filthy. I plan on restoring it to a proper little practice amp, because you can never have enough gear.
Project Logs
Collapse
  • How Much Wood Would Wood Glue Glue If Wood Glue Would Glue Wood?
    Nathaniel Graff • 08/25/2015 at 17:27 • 0 comments
    I was unable to cut out the speaker hole in the face plate, so I went ahead and glued together the outer pieces of the cabinet.
  • Episode IV: A New Cabinet
    Nathaniel Graff • 08/22/2015 at 22:07 • 0 comments
    It is a period of civil war. Rebel spaceships, striking from a hidden base, have won their first victory against the evil Galactic Empire. And I decided today was a good day to break apart the old cabinet and start making a new one.
  • Speaker Repair and Tolex Removal
    Nathaniel Graff • 08/18/2015 at 17:13 • 0 comments
    The speaker cone had some tears in it, including a 1 1/2" long tear along the outside edge which created an audible flapping noise at high output. The others were small punctures, also in the edge of the speaker cone.
  • Testing Audio, Cleaning the Chassis
    Nathaniel Graff • 07/31/2015 at 17:22 • 0 comments
    Since there appeared to be nothing physically wrong with the amplifier, I plugged it in and turned it on. No blue smoke. I plugged in the speaker and turned it on again. A "vorp" emanated from the speaker, and fiddling with the knobs caused crackles and pops. I grabbed a bass guitar I had gotten at a flea market and plugged it in...
  • Jumping In
    Nathaniel Graff • 07/29/2015 at 22:28 • 0 comments
    I started by unplugging the speaker and removing the grill cloth, taking pictures of screw placement and bagging the fasteners together in logical groups. The result was easy access to the collected layer of filth. Bleugh.
View all 5 project logs
Log In/Sign up to comment
Sign up with Github
OR
Always jealous of people who could afford big Nixie Tubes, I rolled my own alternative with WS2812Bs and laser cutting!
Project Owner Contributor
"Lixie", an LED alternative to the Nixie Tube
lixie-labsLixie Labs
I made a guitar amp in the shape of the Head of Medusa
Head of Medusa guitar amp
robbieRobbie
The 2015 Hackaday Prize
A large interactive disco dance floor with hidden capacitive sensors
Interactive Disco Dance Floor
jeremyJeremy
Scored a vintage Sears Silvertone 1484 Twin Twelve guitar amp head and cabinet cleaning out Grandma's, Time to Restore it!
Silvertone 1484 Twin Twelve Guitar Amp Restoration
steal-this-hardwareSTEAL-THIS-HARDWARE
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Guitar Amp Refurbish", please tell us the reason.
Send message
Remove Member
