While testing #Arduino Compatible Zynq Shield added simple non-enhanced DSP48E1 based NCO, one connected to output pin, one connected to on-board LED.
This NCO can run up to 600MHz clock in Xilinx 7 series FPGA's. It can be used as base building block to created enhanced versions of the NCO.
