It's done!
09/22/2015 at 15:28 • 0 comments -
Reduced Power Consumption
09/12/2015 at 14:05 • 0 comments -
IR Transmitter works!
08/25/2015 at 00:30 • 1 comment -
Pin Change Interrupt and Sleep Mode is working!
08/16/2015 at 07:56 • 0 comments -
Learning about pin change interrupt
08/16/2015 at 05:28 • 0 commentsIt is easy to get lost in the 400+ page ATMega328 documentation, so summarized what I needed for my project. Managed to fit it on one page!
Breadboard prototype
08/15/2015 at 16:52 • 0 comments -
Gathering thoughts
08/12/2015 at 06:01 • 0 commentsTASKS:
- Physical design (find button, custom button cap?, how to apply label, should box be 3D printed or laser cut?)
- Electronics and Code
NOTES:
- Record/Playback slider switch.
- 11.5mm vs 16mm buttons?
TODO:
- Get IR receive/record to work
- Get IR transmit/playback to work
- Conserve battery life by putting Arduino to sleep and wake up upon any button press
