2015-11-09
Frame is starting to take it's form.
A mirror that should display information about weather ,temperature and other useful information.
2015-11-09
Proj Log: 20160312
Project finished.
Functionality:
Proj log :20160202
Mirror frame is painted and the screen is tilted to fit the standing mirror.
I had big problems getting the HDMI to VGA up and running.
Great tips were found on this video of how to configure the config.txt file on the Raspberry:
There is much more to read about the subject here
Proj log : 20160109
Everything carefully placed inside the casing.
Extra metal brackets are added for enhanced stability of the casing.
Raspberry Pi with WiFi adaptor and USB cable connected for easy modifications to the operating system.
HDMI To VGA adapter is connected to the screen.
Date: 20160109
All pieces are put in place and brackets are being screwed on to hold everything in place.
2015-11-09
Frame has to be adjusted quite a lot to look reasonably ok.
It is still supposed to be a pretty stylish mirror. :)
20151109
First test to see if screen and glass fits the inside the assambled frame. I have to reinforce the frame with metal clips.
Project has evolved to taking data from my weather station and displaying the result.
Information flows via the MQTT broker.
The mirror now can present , realtime windspeed and inside/outside real temerature.
