Finished Project
04/05/2016 at 18:05 • 0 commentsProj Log: 20160312
Project finished.
Functionality:
- Weather forcast.
- Temp measurement.
- Date parking ikon.
- Google News reader.
- Time/date
First testrun
04/05/2016 at 17:45 • 0 commentsProj log :20160202
Mirror frame is painted and the screen is tilted to fit the standing mirror.
I had big problems getting the HDMI to VGA up and running.
Great tips were found on this video of how to configure the config.txt file on the Raspberry:
There is much more to read about the subject here
Placed and fixed to the case
04/05/2016 at 17:34 • 0 commentsProj log : 20160109Everything carefully placed inside the casing.
Extra metal brackets are added for enhanced stability of the casing.
Raspberry Pi with WiFi adaptor and USB cable connected for easy modifications to the operating system.
HDMI To VGA adapter is connected to the screen.
place and fixed parts
04/05/2016 at 17:21 • 0 commentsDate: 20160109
All pieces are put in place and brackets are being screwed on to hold everything in place.
Frame Adjusting
11/09/2015 at 20:38 • 0 comments2015-11-09
Frame has to be adjusted quite a lot to look reasonably ok.
It is still supposed to be a pretty stylish mirror. :)![]()
Test Assambly
11/09/2015 at 20:29 • 0 comments20151109
First test to see if screen and glass fits the inside the assambled frame. I have to reinforce the frame with metal clips.
