No battery NFC air pressure sensor
Measure tire or ball pressure with your smartphone
This low cost tag is sealed in inflatables such as tires and sports balls to easily measure the pressure. It's powered and read with an NFC-enabled smartphone, which is ever present. Since it has no batteries, it lasts virtually forever.
Visit us at www.roverdev.us
US patents granted and pending
There are several RFID sensor platforms available right now. This will be based on the RF430FRL15X series from Texas Instruments. It has the most flexibility of any low cost energy harvesting RFID sensor platform available at this point, because it's a full blown microcontroller. Other RFID sensor ICs make you live with a very small sensor voltage range, and strange transfer functions. TI's micro allows you to scale the output any way you want.
Analog_pressure_noantenna_r3.sch
Eagle board layout
sch - 345.12 kB - 03/11/2016 at 19:48
Download
Analog_pressure_noantenna_r3.brd
Eagle schematic
brd - 76.72 kB - 03/11/2016 at 19:48
Download
  • 1 × TI RF430FRL152H RFID microcontroller
  • 1 × NovaSensor NPP-301 100 psi pressure sensing bridge
  • 1 × Custom circuit (rigid PCB for now, flexible circuit later)
  • 1 × Smart phone NFC app to read the tag and interpret the measurement
  • New valve concept
    CaptMcAllister11/26/2020 at 21:37 0 comments
    11-26-20 - Faced with some limitations of the design described here and the desire to create an aftermarket product that could be directly installed by the end user, we have developed a new design based on this technology.  This new design is a sensor-enabled valve extension that is installed to bike valves (at this point - other vehicle valves can follow later), and it can read pressure without any battery power.
    The new project required some new equipment and some fairly cool production techniques. Ever seen anyone injection mold into a FDM 3D printed mold?  Neither had we, but it worked great.  Ever seen low volume insert molding of electronics inside of plastic that was in reach of the DIYer?  Neither had we, but that worked great too!
    Since the concept is completely different, we have created a new project page for it.  Check out the new project page at https://hackaday.io/project/176052-no-battery-nfc-pressure-sensor-for-bike-valves
  • Update after two years
    CaptMcAllister09/10/2018 at 02:11 0 comments
    September 9, 2018:  I bet the followers are shocked to see an update on this project.  It's definitely not dead.  In fact, it's been quite busy, but I didn't really know what I should say.  I'll hit some highlights and say that you should expect some more updates in the future.
    On the technical front, we've had several batches of flex circuit assemblies made at contract manufacturers, and they've been installed in footballs, car tires and bike tires.   Everyone who has used them has been very impressed with the overall accuracy and ease of use.   It's pretty easy to get people excited about the technology.
    We did a pretty major overhaul on the firmware in the tag that will enable us to operate with iOS devices.  When we first started, iOS had no NFC support.  About a year later, they added NFC reads, but no NFC writes.  Our original tag architecture needed the reader to write to the tag to request a measurement.  However, for various reasons, we overhauled the firmware, and we should be able to support iOS sometime in the next couple months.
    The app is mostly the same, but we now upload all the data to a web server.   This allows users to monitor their sensor's readings in an internet-connected database.  This is useful for compliance management (making sure your employees are actually checking the pressure), and fleet management (is the whole fleet of trucks, cars, footballs, rafts, etc. running well?).
    From the business front, we made it into another accelerator, and made some good contacts.  I have to say that I am done with accelerators though.  There's so much emphasis on pitching and taking on investors.  For those of us who have a more complicated or risky product (e.g. not just "Uber for hairstylists"), it can be impossible to make any real headway in the actual competition.  The real benefit of the accelerators appears to be the introductions.  If I could do it all over again, I would have leveraged those a bit harder.  It can be hard when you have a real full time job though.  And that was another thing that floored me about the accelerators.  We'd look around and realize that the various startups were everyone else's full time job, where it was just a hobby or pet project for us.  We're not to the point yet where we could quit our real jobs to do this full time.
    Which brings me to the final part of the update.  We are running a beta trial right now with fat tire bike riders as part of a test run of a business to consumer model where we'd sell sensors to bicyclists to monitor their pressure, starting with the fat tire bikers, who run low pressure at varying temperatures on some pretty expensive tubeless tires.  It's easy to get the sensor in, and it works well.  I think we'll learn some interesting stuff from this beta and we'll step and repeat from there.  It continues to be exciting to work on this project, and I expect it will continue to be for some time.
  • Tindie back in stock and flexible prototypes
    CaptMcAllister07/25/2016 at 18:45 0 comments
    July 25, 2016: First off, I finally got the design back to where I wanted it to be to stock it on Tindie, so there's a handful in stock. I plan to build more soon, because those first ones are probably going to sell out quickly.
    Second, I was able to buy inexpensive flexible Kapton circuits from Itead, and it looks like they did a great job building them. I only built one so far, and it works great. I will be building more soon for mounting in tires and balls.
    Speaking of tires and balls, I tried two different types of tags in the first tires and balls. When I got the samples back, one type of tag had died due to the vulcanization process. In both cases, it appeared as though the "gold" pads on the Kapton had corroded. I suspect what actually happened was that the gold plating didn't completely cover the copper, and the copper corroded due to the heat and bloomed through the gold, breaking the trace. These traces were the ones that go to the antenna, so when they broke, the sensor became unresponsive. The type of tag that survived was not a sensor tag - it just served a URL. The fact that it survived is good because it tells me that sensors can survive the vulcanization process, but it's bad because these tags aren't sensors, so their survival doesn't tell me as much as it might have if they were sensors.
    So now the most recent version of sensors (that still have a rigid board) are getting ready for mounting into footballs. I just ordered a solder stencil for the flex circuit array so I can make those 8 at a time. It should be here within a week or so and I'll knock out a couple dozen of the flexible circuits for more mounting into tires and balls.
    Hopefully I'll be having these produced at a contract manufacturer instead of hand assembling them. It will take a fairly big commitment on my part to ramp up production though. I'm not sure I can sell enough to pay for that. I'm working to do some customer discovery to understand my value proposition and so on to determine if this is something that I can sell in any sort of quantity. I'll keep you posted.
  • Many updates
    CaptMcAllister06/03/2016 at 13:37 0 comments
    June 3, 2016: Wow, a lot of things have been going on in the past month. First, we were selected as finalists in the MassChallenge startup accelerator program in Boston. This accelerator provides office space, mentorship, in-kind support, and the ability to compete for zero-equity funding at the end of the program. We're very honored to have been selected, and the judge's feedback has given us a slightly new focus. The feedback was extremely positive. I think they're as excited to have us in the program as we are. The only thing we have to figure out is how we're going to get to Boston, since we're in Minneapolis.
    The second big thing is that we have collaborated with a partner in China to put prototype sensors into bike tires and footballs. We expect to have these back in hand in the next few weeks. It is pretty difficult to seal the large holes you need to make in an inflatable in order to get the sensor installed inside. By installing them before the tire or ball is vulcanized, we will never have to worry about sealing these huge holes.
    Next, we paid the Android developer fee and we're working on getting an app up on the store. Right now we have it installing to our phones from the sandbox, but nobody else can see it yet. We hope to change that in the not too distant future.
    We have to make more sensors. There have been some patient customers on Tindie that are waiting for us to make a new batch. This will probably happen in June. Those sensors will work with the app that will be on the store at that time.
    Finally, we're planning to shift our near term focus a bit and focus on balls instead of tires. The MassChallenge judges were excited about our work partially because it aligns very well with the whole deflategate thing going on. Since they're in Boston, I'm sure they've heard even more than we have about the Patriots and Tom Brady as it pertains to air pressure. They were excited that we could measure the air pressure in a football without having to use a leaky air gauge and stick a needle into the football. So we plan to shift temporarily to balls from tires. We will come back to tires after we get a good ball design.
    We don't yet know how we're going to try to market this. We were thinking of doing a Kickstarter again, since we were successful with the BooSTick, but there may be a better way. Hopefully MassChallenge can help us in that area.
  • Stranded
    CaptMcAllister04/26/2016 at 13:21 0 comments
    April 26, 2016: Since the unrelated flat that I got in the front tire shook the original sensor loose from its attachment, I've been trying to test with a back tire with little success. Last night I had a moderate success that still ended in failure. The issue is that I have been testing flexible sensors for durability. Last night I put a flexible sensor in the original tube. Basically, the tube has a large hole in it as pictured in the gallery, and I put the flexible sensor over this hole and covered it with a large rubber patch as I had before. This effectively put the sensor inside the tube, and no longer was it pinched between the tube and tire. I figured this might help with the sensor cracking issue I was seeing previously.
    I checked the sensor periodically, and it worked happily up to about 5 miles. Then the tire went flat. I wasn't that surprised because I hadn't been able to get the patch to seal properly. Unfortunately, the brief time I was riding on the flat tire without realizing it killed the sensor, so I won't know how long it would have lasted. It appears as though a single component on the back wore through the patch and created a pretty major leak.
    I have one more flexible patch I can try - I think this time I would plan to cut a slit in the tube and try to adhere the patch to the inside of the tube and then patch over the slit. I would remove the single (and unnecessary) component from the back of the sensor so it wouldn't wear through. One issue I'd have to overcome is that tubes are coated on the inside with a powder that makes it hard to stick anything to it. It's there so the tube interior doesn't stick to itself.
    Otherwise, I need to wait for the sensors I shipped to various Chinese tire companies to reach them. It's been over a month so far and none of my three shipments have made it. Maybe I shouldn't have tried to save money by shipping them without tracking!
  • New updates
    CaptMcAllister04/19/2016 at 13:56 0 comments
    April 19, 2016: I have a lot of new updates on this project. Strap in, because this is probably going to be a long one.
    First, I got a flat in the tire that had the sensor in it after about 200 miles of riding. The sensor was in my front tire, which generally gets flats less frequently. I suspected the sensor may have caused the flat, but I was pleased to find that a tiny rock had punctured my tire. I probably need a new front tire. I fixed the tube and the sensor was still functional. However, after one ride, the sensor was not working anymore! I soon discovered that it was because the sensor had come loose from the tire because of all the jostling around when the tire was flat. That bent the patch out of shape a bit and it fell loose inside the tube. I pulled the sensor out and it was still fully functional. This is a hard sensor to kill! I have not mounted it back in the tire yet because of the other updates below.
    The second thing I tried to do was to mount three different sensors in my tire to test for durability. However (and I believe this is key), I mounted the sensors between the tube and the tire. This means the sensors were constantly being pushed on by ~100 psi, and they were probably also constantly rubbing between the tire and tube. Not one of the three sensors lasted for the ~15 mile test ride. Two of them cracked and one of them had the wire antenna wear completely through (all pictured below). At first I convinced myself that the units that cracked did so because I had put epoxy over the components to protect them from the forces of the tire. I figured the epoxy made it too rigid and gave the sensor an opportunity to crack rather than flex. I tried another of the TI Kapton sensors without epoxy and it cracked as well, so I knew it wasn't the epoxy. The sensor that wore the antenna through gave me a few more clues. In that picture, you can see a faint vertical line that goes right through the failed point on the antenna. That line corresponds to a parting line on the tire tube, that had some extra rubber flash. The flash appears to have worn through the antenna, even though it was protected by a cover layer not present in the picture. This fact and the fact that the successful tag had a very similar Kapton antenna tell me that the real issue here is that the tags are between the tire and the tube, not that the flexible design in general is flawed. More updates below the pictures.
    The final update is that I have sent some of the very flexible designs to a few tire manufacturers for test mounting inside tubes. The sensors will have to withstand ~200 C temperatures for the vulcanization process, but if they do, it will answer tons of questions for me. Even if they don't survive, I plan to do some beta testing with these tubes for a few hundred miles and then cut them open to see how the sensor substrate physically fared. However, the tire manufacturers are in China, and none of them have received the sensors yet because I tried to send them via USPS to save money. Seriously, it's $1.20 to send an envelope to China through USPS, but jumps to $60 when you add tracking. Problem is, nobody has received the sensors yet and I have absolutely no idea where they are. They will probably show back up in my mailbox in a month or so as undeliverable for some reason.
    So that's where I am. I am just coming off the successful Kickstarter for the BooSTick: https://hackaday.io/project/7050-boostick-small-aa-voltage-booster, so I am starting to look at this one a lot more to figure out how to proceed. I can tell you it is pretty cool to have that sensor in your tire, and I have used it quite a bit more than I would have guessed.
  • Hand wired flexible sensor
    CaptMcAllister03/12/2016 at 20:24 0 comments
    March 12, 2016: TI got wind of my project and was kind enough to send me some flexible patches that they had made. I finally got around to hand wiring a pressure sensor and voltage regulator onto one of them, and I'm pretty proud of my work (pictures below). I did this one quite a bit different. There's no differential amplifier, so my signal is very tiny AND it's biased toward the high rail, so I can't use the gain stages inside the IC. The pressure signal is measurable though. I don't think I would do away with the op amp if it weren't such a pain to hand wire in. I also used a capless voltage regulator to provide me with a more predictable voltage than the RF430 can. This way, I don't have to spend ADC time (or more hand wiring) measuring the pressure bridge's reference voltage. This one is going to get the components epoxied and it's going into my BACK tire. It's about to have a hard life. We'll see how it turns out.
    On a related note, the original sensor is still going strong after 90 miles in the front tire. Still no leaks, still no problems.
  • Still holding up
    CaptMcAllister02/28/2016 at 20:24 0 comments
    February 28, 2016: The patch has remained in my tire all winter, and the tire has held at least some air all winter. The weather was nice yesterday so I took a 15 mile ride and the patch is still holding up great. After the ride I was able to see that my pressure was 83 psi. Everything has gone very well with this first design. I am still trying to figure out what to do with this, since the flexible patch would cost so much to make.
  • Flexible patch
    CaptMcAllister02/19/2016 at 15:03 0 comments
    February 19, 2016: I created a flexible patch design that is suitable for lower pressures, and had some prototypes built. These prototypes consist of a Kapton flexible circuit on a PET carrier. The antenna is wound with magnet wire. These work very nicely and they give me a great deal of confidence that I could have higher pressure units created for a low cost and still achieve excellent pressure performance. I would like to make these new patches in higher volume, but the quantity order is too high. I have thought of turning to crowdfunding, but I'd need to know first that people were interested. I posted the original design on Tindie (https://www.tindie.com/products/CaptMcAllister/rfid-pressure-sensor/) for people to sign up for a waitlist for the original revision. If you're interested, please head over and sign up. If I get enough interest, I will look to crowdfund the flexible version.
  • Design files in github
    CaptMcAllister12/03/2015 at 03:08 0 comments
    December 2, 2015: Files have been uploaded to Hackaday project page. There are native EAGLE files for the schematic and board, a CSV file for the BOM, and Gerber files for the PCB.
View all 27 project logs
View all instructions
nair.vi.1337 wrote 02/12/2019 at 17:32 point
Hi bro,
Awesome project.. I'm also planning to make a similar kinda project... I will be using npp-301A 100PSI IC combined with MAX1472AKA+T RF TRANSMITTER... But problem is.. I'm a software engineering student.. and have no much idea about circuits... Can u or anyone plz help me to plot a circuit for the same..
Guide me if possible
Thanks a lot in advance
Elma wrote 11/15/2018 at 05:10 point
Such a cool project! How did you program the patch? Did you use the active cable from TI, over-the-air-programming or the Code Composer Studio?
ESotta wrote 01/04/2018 at 14:33 point
I found this sensor very interesting and I wish I could test it on agricultural tires and OTR. I am a developer of solutions for industry so I would like more information about this sensor, as I do to get in touch. My contact 55 11 94754.2935.
ESotta wrote 01/03/2018 at 19:50 point
Achei esse sensor muito interessante e gostaria de poder testa-lo em pneus agricolas e OTR.  Sou um desenvolvedor de soluções para industria entao gostaria de maiores informações sobre esse sensor, como faço pra entrar em contato.  O meu contato 55  11  94754.2935.   edu_romano@hotmail.com
Brian Buch wrote 04/07/2017 at 22:42 point
this a very interesting concept. I work in the retail tire industry and am interested in hearing the latest progress on your efforts. Have you been able to reliably attach to inside of a car tire to read pressures
CaptMcAllister wrote 12/22/2017 at 01:30 point
Yes, actually, tires are of high interest, and we have tested in tires, and they stick extremely well.  You can look us up at roverdev.us, and please reach out if you have any questions.
Sorry for the very late reply.  For some reason, I am not getting notifications when people leave comments.
Chris Short wrote 07/12/2016 at 19:18 point
Since you're stateside I'm going to assume you're talking about American Football in your most recent log entry.  Becaause of that of course a Boston based accelerator is going to support this.  It'll help their beloved team avoid the next deflategate scandal.
All around awesome project and looking forward to seeing bike tires being available.
CaptMcAllister wrote 07/12/2016 at 19:23 point
Thanks.  I think there's a mix of Bostonites that think it would be a good thing and those who just want it to go away.  I was actually surprised at the number of them who like the idea.
I'm back and forth between whether tires or footballs will be first.  I like biking, and I really want this for my tires.  I realized that every time I go for a ride, I have to connect the pump to check the pressure.  Connecting the pump causes a leak that requires me to repump, so every time I ride, I have to pump up the tires.  If I had sensors, I'd just give them a quick check and be on my way 9/10 times.
There are a few problems (including the smaller size) in making bike tires work, but that's still my goal.  The accelerator has been very helpful so far, and I hope to keep leveraging their expertise to try to make a Kickstarter happen.  There's so much to do right now though!
colonwq wrote 01/23/2016 at 20:13 point
Instead of square or round, have you though about designing the sensor to be long and thin? It could fit in the tube via a small slit and fit in the curve of the tire/wheel.
CaptMcAllister wrote 01/23/2016 at 21:30 point
Good question.  For this more flexible prototype, I had to go with whatever flexible antenna was available off the shelf.  That turned out to be the Taoglas.  The signal reception is ok, but the patterned antenna I made on FR4 had better range.  There were no long and thin flexible antennas available.
In the future, I would consider a longer, thinner antenna, but my understanding is that thinner antennas are less efficient for HF RFID tags.  That's one reason you always see square and round tags.  If I could hit a sweet spot between read distance and aspect ratio, it would be great!
alpha_ninja wrote 12/07/2015 at 00:38 point
[verified: no design files missing]
alpha_ninja wrote 12/02/2015 at 00:47 point
This is your one-week reminder to upload design documents: https://hackaday.io/project/7813-the-square-inch-project/log/28566-design-deadline
Alasdair Allan wrote 11/11/2015 at 14:44 point
Really nice project. First use of the new generation of sensor-enabled NFC tags I've seen. Are you intending to release the EAGLE (or Gerbers) or other design files for the PCB at any stage?
CaptMcAllister wrote 11/11/2015 at 14:46 point
Thanks very much.  Yes, I will release the files.  I have to do a few cleanup things first.  I expect to have them up within a couple weeks.
zakqwy wrote 11/09/2015 at 15:32 point
This is awesome! I've never putzed about with NFC stuff (or flexible PCBs for that matter). Great job!
CaptMcAllister wrote 11/11/2015 at 14:54 point
Thanks very much.  I appreciate the support!  If you wanted to work with this, TI has a pretty nice eval kit.  It's the RF430FRL152HEVM, available all over.
alpha_ninja wrote 11/06/2015 at 15:59 point
Looks like you could enter the #The Square Inch Project with this (if you're interested) :)
