Update: more info here
http://pastebin.com/ZYFYtTt3Not sure if there is s better way/place to post or dump info but here goes :
Transcribed from the program defcon times
Page 2
VgjbhyqagorQrspbajvgubhgbhetbbqsevraqPnrfne
(fbzrgenqvgvbafjvyyarireqvr)
Hjvyyxabjjung2qbjuraHhafpenzoyr “Ubjqnqqlvfqbvat”
WFST HDXE HGY BNK BAWH QJG PSOR WNFATG IDDW OQUHVNKINGCY GQG CTUK.
Also the binary from the handout today
01000100 01000101 01000110 00100000 01000011 01001111 01001110 00100000 01010000 01100001 01110010 01110100 01101001 01100101 01110011
Just converts to DEF CON Parties ;p
On the number cipher, I tried all possible alphabet rotations, then mirrored the cipher wheel and tried all rotations again. It's not using a rotation cipher. I tried letter frequency analysis but this was difficult because the message is so short. A longer message would be too easy, wouldn't it?
The DTMF decode is T9, netting you the following two blocks delimited by "105710571057"
[1] = DJANDMTFAN
[2] = PEJDWPARGPDPDGPWDAPDTGDMTPGAMAJDQAMDWDAPDTGEPDAMDQMEPDAMP
Not sure if I'm working the decrypt correctly on the block 2 or not. My attempt at a key...from working the ciphered text's common single/double/grouped letters nets definite words...but results in my words of "WTF does that mean?!".
What key gave you words? I can take a look at it...
Don't know if it helps, but the Letter Number "cypher" decrypts to:
Z R J N U E Q M Q S V V T S V V H G H V L Y A N X L T B X L X J G G F N R B V Y R C F X G Y K I P N V L A X I Y B Q V I Z X E E T X G W Q R D M B K V W X K A G B K S F B M L Z I R M P X N L R E
26 max number = Alphabet Letters
