A small display for reading your robot's serial data debug output.
While this project pretty much works and serves its purpose, it's not the most ergonomic design on earth. So I decided to make an even smaller version, this time with a more thought out user interface. I called it #Nano TTY, because it's even smaller than the Micro TTY here. It uses pretty much the same idea, but has an OLED screen for display and a rotary encoder for scrolling.
A few lines of code later I have a nice 64-line buffer that I can scroll through using the buttons. I can scroll by line and by page, and I can also pause collecting data, and start it again.
So far, the buttons don't really do anything useful -- they send "Button n" over the serial. But that is going to change in the future software updates.
This tiny screen is really too small to see all the information that you need, so I will need to add a scroll buffer to this device, and then I can use the buttons to scroll the output.
Great to hear you build it too. To be honest, I didn't even think about the current on the VCC, I just tried and it worked, so I left it that way. Mine is also a cheap clone, but apparently it happens to have a better voltage regulator. The contrast setting also depends on the light, etc. -- again, I used what worked for me. No idea why you had to clear the screen, each line should clear what was there before...
Having a case and putting buttons on the side would probably help a lot, right now they are pretty hard to use. Also, using a screen with higher resolution for more lines at once... Maybe some day.
In the picture, it looks like you've tied the buttons to reset. Am I crazy?
Actually that's GND. The markings are a little bit confusing on those boards, but if you look at the first one, you get it right.
I'm really quite annoyed that I haven't seen this before - this is a great tool to be kept on hand for quick and easy debugging.
Love it!
Hi,
Great looking project. Are you able to upload the current code?
Cheers,
Scott
Brilliant! I'm using these screens on the MeArm and adding a promini clone would be a simple upgrade. Thanks for sharing, hope to read more soon!
Speaking about MeArm, I just got one and I'm going to do things to it. Thank you for this great design, it was really easy to assemble.
Thank you! After looking at your designs I'm really pleased that you're going to turn your eye to the MeArm!
Fun project. Just built one, and hit a couple of stumbling blocks that I write up to slightly different hardware.
I had to jumper VCC straight to the screen -- the (cheap, clone) Arduino mini that I was using didn't have enough juice to power the screen through the GPIOs.
I also had to tweak the contrast setting -- to 50 -- to get anything visible on the screen.
Finally, I needed to add a display.clearDisplay() into the display_buffer() function, just after setting the cursor position. Otherwise, it was overwriting lines all the time.
I haven't added buttons yet, because I'm thinking of putting the whole thing in a case, but so far, so good! Cool toy.
