Mid-day update: April 20, 89 PD
While over 75% of the internal parts are finished printing, but there is still too much to do. We have started wiring up the reactor with LEDs but it is slow going (25% done). We have not even started on the code to drive the lights or any interface stuff. This is starting to feel like my senor design project all over again; work every minute you can and then when it is a week before it is due, time for no sleep.
Plans:
- order: plastic for impeller ring and Laserhead Telemetry Array; flex tubbing; caffeine
- Finish the Impeller drive today
- Finish nuke today
- Start RCS ports today
Other notes:
Not everything that can be drawn can be built (words to live by). I have cut the number of nodes per ring from 8 to 6 because there is no way to get 8 properly scaled Impeller drives in both the stage 1 and stage 2 rings. I may redesign the drivers at a later date to do an 8 node design.
