To be honest, we didn't design the Pulsar with a specific use in mind. We simply wanted a way to include multi-colored lights in our projects without too much hassle, and be able to control them wirelessly.
To give you a taste for what we've built so far, here are a few examples:
Iron Man Costume
From Comic-Con to Maker Faire, the Pulsar allows us to build costumes of varying degrees of complexity. An Iron Man t-shirt works great when you're in a pinch for a costume party!
The Pulsar also makes a great addition to our 3d-printed repulsor arm! Check out the CAD model files courtesy of our neighbors at @Deezmaker!
International Space Station (ISS) Monitor
In collaboration with the creator of ISS Above (@Liam Kennedy), we developed custom firmware so that the Pulsar would display a countdown until the next pass of the ISS using beautiful LED animations!
The data are loaded wirelessly onto the Pulsar from a Raspberry Pi equipped with a USB Bluetooth LED adapter!
3D-Printed Night Lamp
In collaboration with our awesome neighbors over at @Deezmaker 3D-Printers we developed a 3d-printed night lamp that can be programmed as a soundless alarm clock from any bluetooth-capable device!
We're excited to see what you'll create using this neat little device!
ACROBOTIC Industries
Nicholas Stedman
Markus Loeffler
The Virtual Traveller
makeTVee
great...maybe APA107 LED source is better choice
https://issuu.com/newstarleds/docs/apa107_led
