Support Our Indiegogo Campaign
04/04/2016 at 10:16 • 0 commentsNow we are running an Indiegogo campaign. Help us to build indoor vertical farming system and automated greenhouse in Indonesia. You can check the campaign here.
Setup the Raspberry Pi
08/09/2015 at 04:49 • 0 commentsThis lovely Sunday, I'm testing the Raspberry Pi local timer for switching on and off the lamp. It has not connected to the internet yet. My next step will be adding the temperature sensor and connect it to the fan.
I'm using Clojure for controlling the Pi's GPIO.
Sprouting is success
08/07/2015 at 07:41 • 0 commentsThis photo is taken at the day of 8th. The sprouts look healthy. At this stage, we are only testing the lighting, aerator, and fan. The server side application is still under progress.
Asep Bagja Priandana
