Making Idler Modules
09/21/2015 at 14:11 • 0 comments![]()
Adding Loader Arms and Quick Attach Plate
09/20/2015 at 16:20 • 0 comments -
Cab Module
09/20/2015 at 16:16 • 0 commentsConfiguring the Cab Module.
Experimental Clamp Collars
09/20/2015 at 16:09 • 0 commentsThese clamp collars hold the idlers, sprockets and lift arm pivots in place on 3" shafts using friction alone. This greatly simplifies fabrication by eliminating the need to mill keyways in the shaft.
Prototype Fabrication Day 2, Project Video
08/17/2015 at 03:26 • 1 commentA video about the project:
Day 2 of building the prototype
MictroTractor Module:
PowerCube Module:
Universal Rotor Module:
Working on Idler Module:
240 track chain links:
Prototype Fabrication, Day 1
08/16/2015 at 12:59 • 0 commentsCutting pieces for track module, idler module and track platform module.
Hydraulics Schematics
08/14/2015 at 03:42 • 0 commentsWorking on the configuration of hydraulic valves for operation of PowerCube modules in series or in parallel. See the working doc here.
Bulldozer Log
08/10/2015 at 23:24 • 0 commentsWorking on infographic.
marcin
