The results are in!
09/23/2015 at 22:04 • 0 commentsThe first successfully plated board was done with the following parameters:- Plating bath: Original Thinktink recipe w/o any additives (just distilled water, H2SO4, CuSO4 and a drop of HCl), at room temperature with bubble agitation.
- Pulse current: 19/1ms pulse duration, 1/3 pulse amplitude, 2A/dm² average current density (roughly 20ASF)
- Anodes: Copper heating pipes (I might even have grabbed phosphorized copper pipes by accident)
- Plating time: ~3h
- Added copper thickness: ~50µm
- Copper surface: bright and dull
I made a few cross sections by cutting off a slice of a test board and sanding it down with 600 grit sandpaper. Here is the result:
The two leftmost holes are 0.3mm, then a pair of .4, then two .7s and finally a .8 at the right. Apart from the right .3 hole, which is clogged with paint, all the holes are plated beautifully. The right .4 hole looks a bit iffy, but that's because I poked around in there with a knife. And that dark spot in the rightmost hole is just a shadow. Also, the copper on the top seems to be much thicker than on the bottom, but that's just an optical illusion from the lighting.This is a close up of a 0.3 hole I made with an improvised usb microscope. No Idea what magnification this is.
It's clearly visible that the copper on the hole walls is at least as thick as on the surface, which supports the theory that pulsed reverse current improves throwing power. If you look closely and with a bit of imagination, you can even see the thin black layer of conductive ink between the copper and the substrate.
Here is another one showing the whole barrel:
It's a bit blurry, but here you can see the carbon paint on the hole walls even better. And it nicely illustrates the aspect ratio of the hole. That's a 0.3mm hole in a 1.6mm board. Plated in a home lab. With tools and materials for less than a hundred Euros.Well, that's it, I'm done. I could muck around with additives like PEG and try to get a shiny surface, but why bother? Plating holes works amazingly well, and the following process steps don't care about looks. In retrospect, I must say the trickiest part was getting the conductive ink right. The conductive screen printing paint from Peters is definitely the right tool for the job, but might be hard to get in some parts of the world. But then, there might be other things available, like Higgins Black Magic ink, which I hear works very well, also. The PCB for the current source only took that long because I was experimenting with other process steps which screwed up a few tries.
The code, schematics and layout for the current source are in my github, as well as the CAD files for the guts of the process tank. So go and buy a PE food container, copper sulphate and a bottle of battery acid, fire up your hackerspace's laser cutter, throw together a current source, and plate your own boards!
First test board etched
09/19/2015 at 23:47 • 0 commentsFirst things first, all the .3 to .7mm vias have no measurable resistance (measured with my cheapo multimeter). Other than that, there are a few things wrong with this board: The CNC router shut itself down in the middle of a drilling cycle, and after that, the Y axis was slightly off, so the .8 and 1mm holes are all in the wrong place. Also, I printed the film the wrong way around, but I didn't even notice until the board was etched.
This is a 1.6mm board, which makes the aspect ratio of the 0.3mm holes roughly 1:5. I'll have to figure out how to make a clean cross section of one of those holes to look at the wall thickness, but still, that's quite impressive for a bottle of battery acid and an old PC power supply.
Uploaded a video and linked sources.
09/19/2015 at 10:31 • 0 comments -
It actually works!
09/19/2015 at 00:11 • 0 commentsThe conductive ink arrived and I gave it a try. I forgot to thin it, so it clogged most of the 0.3 and 0.4mm holes, but the bigger ones mostly turned out beautifully. From left to right the holes are 0.3, 0.4, 0.7, 0.8, and 1.0mm, in rows of two.
The current source is up and running!
09/06/2015 at 22:23 • 0 commentsI finally finished the current source (uploaded a picture). Now I just need the conductive ink to arrive and prepare a few test boards.
Conductive ink sample on the way
09/03/2015 at 15:24 • 0 commentsI asked Lackwerke Peters for a sample of their SD 2843 HAL conductive screen printing paint, after reading on the EEVBlog forum, it has been successfully used for holewall activation. Well, today I got the answer: They'll send me 250g as a free sample! I don't think I'll ever have to buy any of the stuff now!
THANK YOU, Lackwerke Peters, for your outstanding generosity! You are awesome!
Current source still not assembled..
09/03/2015 at 15:08 • 0 commentsBut the soldermask is now properly UV- and heat cured. And my reflowing/annealing/curing-toasteroven has a new profile now, for curing soldermask.
Finally, a PCB I can live with!
09/02/2015 at 09:58 • 0 commentsThe PCB for the current supply is done. Finally. I hope I'll find the time to assemble it tonight.
PCBs etched, but with many defects
08/27/2015 at 08:31 • 0 commentsI'm still tweaking my process, so I tried to laminate the photoresist at a lower temperature, which seemed to have an adverse effect on adhesion, plus I tested my new horizontal bubble etching tank design, which still needs a lot of refinement. How many tries will it take me to get this right?
New PCBs drilled.
08/21/2015 at 10:28 • 0 commentsWith the right size holes, this time. I didn't even break any endmills!
